Brief Description: Drilled Pitch Servo Bracket/Moved Elevator Bellcra
Made new spacers for elevator bellcrank to move bellcrank farther right. This allows the pitch servo to be bolted to the bellcrank on the left side and have the control rod parallel the F-689 rod. Positioned and then drilled the pitch servo bracket to the F-629 and the bottom of the fuselage. Drilled three large holes on the bottom of the bracket so the bracket sets over the fuselage rivets. Drilled two #40 holes thru the bracket and the fuselage between the existing rivets.
