Brief Description: Drilled Bearing Blocks to Proper Size Holes
Drilled holes in flap bearing blocks up to 3/16''. Placed blocks in drill press jig. Drilled bolt holes thru center bearing blocks and flanges. These holes came close to other holes that had been previously drilled erroneously. I made up two spacers to be placed under flanges for the nutplates to be riveted to.
