Brief Description: Trimmed seat ribs/floor for stick movement
Trimmed the flanges of the seat ribs for more aft left and right movement of the control stick. Drilled pilot holes and then used snips. Used die grinder to smooth edges. Drilled corner holes and then used Dremel tool and cutoff wheel to cut out area in floor panels for control sticks. Actual cutouts were approximately 1/4'' undersized on all sides. Cleaned up edges with die grinder,
