Brief Description: Drilled Static Ports in Fuselage
Drilled 1/4'' holes in each side of the fuselage using a unibit for the static ports. Marked and drilled 6 pilot holes in each static port. Clamped each port in position and drilled rivet holes up to size. Deburred all holes. Swept out fuselage.
