Brief Description: Modified Seat Ribs and Spar Flanges for Control St
Marked off the areas on the seat ribs and main spar flanges that will be cut out for the control sticks. Drilled holes in the corners and then cut the flanges using a cut-off wheel in the Dremel tool. Smoothed edges with the die grinder and Scotchbrite wheel.
