Brief Description: Cut Spacers for Pitch Servo/Dimpled Fuselage Bulkh
Used die grinder to debur some holes in the bulkheads. Used pneumatic squeezer to dimple all bulkheads and rib F-6?. Vacuumed out fuselage. Positioned pitch servo in fuselage. Cut two 4 1/2'' lengths of .063'' a half-inch wide to be used as spacers for riveting pitch servo to rib. These are needed to remove interference on the movement of the servo control rod to the bellcrank.
