Brief Description: Nutplates for Left Forward Floor/Trimmed Right Fwd
Installed nutplates on ribs for left forward floor. Trimmed right lower corner of F-604 with Dremel cutoff wheel, so that right seat floor will set properly next to bulkhead. Trimmed right seat floor in the right corner so the floor will fit into corner better. Did not drill holes in rib that will be modified for control stick, other than the aft-most hole. Drilled right seat floor into position on far right rib with #40 pilot holes.
