Brief Description: Riveted Electric Flap Components Together
Riveted nutplates onto EF-603 and then riveted EF-603 to F-605C, using the pneumatic squeezer. Used rivet gun and tungsten bucking bar to rivet EF-604 to EF-601. Used the battery from the portable drill to run the flap motor and extend the arm. Positioned the WD-613EF flap rod in position and then placed the EF-601 in position and screwed it in. Bolted the flap motor rod to the flap rod. Ran the flap motor up and down using the drill battery as the power source and found no problem.
