Brief Description: Drilled Left Armrest to Fuselage and Dimpled
Drilled left armrest to fuselage. Found that I did not position armrest aft bracket up against F-605C bulkhead. I made another bracket and drilled it to the F-605C, then to the armrest. Used pop-rivet puller to dimple fuselage holes. The nails had to be sanded with die grinder in order to pull dimple die off for the next hole.
