Brief Description: Cut out Armrest from Stock/Engine Stand Components
Used Mike Snook's plans to make an engine stand. Bought the stand at Harbor Freight. Picked up hardware, threaded rod and pipe to make engine stand. The pipe ID was too small. Need to get a larger pipe. Cut threaded rod in two and bent the ends of all four pieces per the plans.
Marked armrest dimensions on aluminum stock. Used bandsaw to trim edges. Smoothed all of the edges.
