Brief Description: Widened Seat Belt Openings in Seat Floors
With the seat floors in place, attempted to position seat belts in place in brackets. I found that the openings cut out in the seat floors restricted the brackets from accepting the seat belts. Used the Dremel tool and a sanding wheel to make the openings larger.
Original Openings for Seat Belts-Not Wide Enough
Seat Belts in Place after Widening
Bracket on Left Widened-on Right Needs to be Widened
