Brief Description: Positioned Pitch Servo and Bracket
Shortened spacer on Scotchbrite wheel for elevator bellcrank bolt on Scotchbrite wheel. Bolted elevator servo to bracket. Measured control rod distance. Bolted bellcrank in position with all appropriate spacers/washers. Attached control rod to elevator servo and clamped into position on bracket and attached control rod to bellcrank.
