Brief Description: Drill Left Side of Pedals to Master Brake Cylinder
Connected the left side rudder pedals to the rudder pedal assemblies. Used long bolts, AN3-56, to connect pedals to rudder pedal assemblies. Inserted washers as needed. Attached brake cylinders to rudder pedal assemblies. Followed Dan Checkoway's method for drilling pedals to brake cylinders. Clamped rudder pedal assemblies to boards clamped to bench. Positioned pedal assemblies in neutral position. Clamped ruler to pedals for alignment. Marked brake cylinder hole on pedal and drilled holes in each pedal. Deburred holes. Bolted each brake cylinder to rudder pedal, using four AN3-960 washers between pedal and brake cylinder. Attached VA-118 hoses to master brake cylinders. Attached 269-N-04 brass elbows to all master brake cylinders.
Left Side Pedals/Master Brake Cylinders with Hoses
Master Brake Cylinders Bolted to Pedals
Top of Master Brake Cylinders Bolted to Pedal Assemblies
