Filed notch in bellcrank for NavAid rod clearance. Reattached aileron control rod, bellcrank, & NavAid rod. Attached aileron control rod to rod end bearing by rotating it 6X past hole. Attached aileron control rod to rod end bearing in bellcrank by rotating it 4X past hole. Found aileron movement to be 2?° up & 1?° down.
