Brief Description: Left Inboard Aileron Hinge Bracket
Used belt sander to smooth JB Weld applied to bottom of aileron hinge bracket. Took aileron off spar. Positioned bracket on rear spar & drilled short bracket to spar. Countersunk the four holes in spar under bracket. Marked position of four holes in spar under bracket onto bracket. Then marked & drilled five holes in bracket. Deburred all holes.
