Baker's RV-6
RV-6
Bolt Left Main Ribs to Spar
Bolted main rib 4 to main spar. Using torque wrench, torqued bolts to 23 in-lbs. Used pop-riveting tool to rivet rib flange to main spar. Repeated same for ribs 3-1, then 5-8.
Ribs 4 and 5 Riveted to Main Spar
Ribs 2-4 Riveted/Bolted to Main Spar
Rib 5 Bolted to Main Spar
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
