Baker's RV-6
RV-6
Rivet Left LE Skin to Spar
Used #41 reamer to clean out holes along leading edge skin & spar. Used pneumatic squeezer & 426-3-4.5 rivets to rivet leading edge skin to spar.
Had to leave two holes open. Need to use needlenose squeezer because of a bracket in the way. Done 2/5/07
Left LE Riveted to Spar
Tubing for Wire Run thru Rib 9
Top of Left Wing
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
