Using measurements from Dwg. 16, drilled 1/16" pilot holes in aileron brackets. Drilled same size hole in pressed board to provide guidance in drilling remaining hole in other side of each bracket. Checked positioning of aileron on wing. Found inboard portion of aileron too close to gap fairing. Filed hole on inboard bracket to draw hole closer to aileron. Drilled pilot holes up to 1/8" size in both brackets. Checked positioning of aileron on wing again. Took gap fairing off & used hand squeezers to reduce radius of inboard 8" of fairing. Clearance of aileron/gap fairing looked ok so drilled holes in brackets to 3/16". Pinned aileron to wing. Measured inboard portion of aileron to be 5/32" away from top skin & outboard portion of aileron to be 11/32" away from top skin.
