Cleaned right leading edge skin edges w/Scotchbrite pad in die grinder. Used Scotchbrite pad on inside of skin. Wiped down all skin panels w/lacquer thinner and then enamel cleaner. Sprayed acid etch on all panels and rinsed off with water. Primed all panels. Did same to all 4 W-425 ribs.
