Greggs RV-4
Date:  2-27-2015
Number of Hours:  2.50
Brief Description:  Worked on F411 and 412 area with tailwheel spring
Not a lot of words necessary today. Worked on the area between F411 and 412, where the tailwheel spring mount goes. It is hard to get the spacing right between those 2 bulkheads, and if you aren't careful, the tailwheel mount will NOT fit properly. I clecoed the mount to the bulkheads, and used THAT for proper bulkhead spacing, instead of the other way around.
F411 and F412 with tailwheel mount
Pic is crooked, not the fuse.
