Brief Description: Worked on F411 and 412 area with tailwheel spring
Not a lot of words necessary today. Worked on the area between F411 and 412, where the tailwheel spring mount goes. It is hard to get the spacing right between those 2 bulkheads, and if you aren't careful, the tailwheel mount will NOT fit properly. I clecoed the mount to the bulkheads, and used THAT for proper bulkhead spacing, instead of the other way around.
