Greggs RV-4
Date: 10-26-2014
Number of Hours: 5.50
Brief Description: LH Tank work - lots of it.
Today was a great day progress wise. I decided to get back on the LH tank. I deburred and dimpled the skin, then scuffed all rib lines, area for the drain, and area for the flange. I then scuffed all the inner ribs, the flange, and the drain. Next was drilling the vent holes and vent line holes in the ribs. After everything was CLEANED, I made sure everything was deburred, and well scuffed for the sealant to have some 'teeth'.
I mixed up a good size batch of sealant, and went to work with it. I started with sealing the stiffeners, and dob sealing the rivet holes on them. Then I sealed in the tank drain, and flange, and riveted them on for good, followed by dob sealing the rivets on each. Lastly, I sealed the rib lines and flanges of the inner three ribs, and riveted the lower half of those three ribs to the skin. I ended the day by dob sealing the rib rivets, and fillet sealing around both sides of each rib.
Tank flange countersunk and ready to seal
Tank drain drilled and ready to seal
3 inner ribs riveted in! (lowers)
