Greggs RV-4
Date:  9-20-2015
Number of Hours:  1.50
Brief Description:  F409 Bulkhead new flexi-flange
This evening I tackled the 409 bulkhead.It had some oil canning (common at the 408-409 bulkheads), and I had been considering options for quite some time. Finally, I just decided to cut the factory flange off, and make a new flange out of .032 angle. Sort of time consuming, but not diffucult. I fit and drilled the new flange to the bottom skin FIRST, and then drilled the flange to the bulkhead. No gap, no oil canning. Drum tight!
.032" angle - soon to be a bulkhead flange
Getting closer
Getting closer
New flange clecoed on
