Tested the lite strip of LED's by taping to the under edge of the glare shield. Approximation of position and full power (undimmed) illumination.
Removed the oil filter FW recess (un-riveted) and cut the hole for the eyeball control cable (mixture). Picture shows hole & partial fitting installation as mixture cable passes through. Length is perfect to the bracket and servo lever.
Replaced the 44.5" throttle cable with the 46.5" version, which is a perfect fit for the routing.
