Disassembled servo & cable mount/bracket components and finished fabrication of brackets (the actual piece that holds the cables).
All photos are with temporary nut/bolt combinations, and NOT to illustrate final fastener types and fit. Castle nuts make good substitutes for lock-nuts - And are easy to hand tighten for assembly fit testing.
Match-drilled the brackets and cut appropriate spacers from tubing to get alignment of swivel-ends. Trimmed and deburred items.
Removed one of the sump studs, but will have to heat sump to remove the other three, and insert the AFP supplied longer studs. Need to paint or treat bare AL pieces.
