More fitting and enhancements of the brackets for the AFP servo cables. Trimmed and deburred the throttle bracket and tested the range of adjustments for cable travel.
Riveted the nutplates in the FAB top plate. Attached and determined clearance. No problems.
Trimmed several areas on the AFP mounts, excess length on mixture side, and removed interference with cable nut.
