Modifications to the AFP FM-100 mount required because of the conical engine mount, interference with the mount tubes. Necessary to route the throttle and mixture cables to the outboard sides of the tubes.
On the Rt side, the throttle cable bracket is from a low to high position to move from idle to WOT, but the mixture cable direction is from high to low to move from Idle-Cut-off to Full Rich.
The Mixture cable mount from AFP is being used with extensive modification. Turning it 90 degs and trimming off some material that interfered with Servo body, and then bringing the mixture cable bracket down from the mount.
