Instructions call for fitting as needed based on the many variations in models and it's NOT a 'one-size=fits-all' option. It's a one-size-can-fit many with customization.
The AFP servo does not sit on the centerline of the aircraft, instead sits to the left at least 1". Therefore, the FAB is cocked to the left, but the snot is still centered on the cowl snorkel.
There is a re-iterative process of clamping, moving, installing the lower cowl, and repeat.
This is all preliminary fitting, until the AFP cable mounting plate is installed the height of the servo is 1/8 to 1/4" high. The angle of the snot will need to be adjusted.
