Finished terminal strip for AP circuits under right seat pan, between ribs. Added the AP power & Disconnect/CWS connections (Roll & Pitch) plus the SV-Net for Roll. Removed a portion of conduit to run bare harnesses instead.
Added AP Level wiring, including harness sleeve, shrink wrap and terminations.
Added DB9 for Serial cable connector to SV-D1000 (Display). Added Serial ground pin to J2 conector.
Other connectors, wire harness retainers, and shrink wrap. Tested RFI from laptop which is also causes hiss on A/C radio.
