Mounted the RAM ball on the instrument panel right side in an area which will be cut-out for a 2nd MFD at some future time. In the meantime the iPad will be the 2nd display. The iPad will run ForeFlight and carry the EFB/Moving Map functions. With the WiFi from the SkyView it will be a 2nd flight instruments display for the co-pilot or passenger.
Added the power plug and tested the USB power module for RFI, with no problems found.
Found a problem with Right side headset jack, dead. A SteinAir harness and need to find out how to troubleshoot this one.
