Brief Description: Vetical Power - VP-100 replacement
Started the process of checking my wire labels, cataloging the transition from the VP-100 to a new VP-X Sport.
Although the infrastructure of the plane's wiring is remaining, the connector assignments for all the termination into the VP-X is changed. Example the two 'flap power' wires from the VP-100 (J3-1&2) will now be plugged into J10-9&10. [correct this ...]
Vertical Power VP-X Sport requires switch inputs which are not supplied, with the removal of the VP-100 Control Head. This will require a row of new switches and I reviewed a variety of toggle and lighted rocker switch choices. No decision yet.
