RV-6A - GBC
Date:  5-26-2013
Number of Hours:  4.00
Brief Description:  VP-100 mounting tray - design
Reviewed the position and relationship of electrical control center to other electrical components, and SkyView components.
Not much to show for the effort, but the planning was productive. Also fabricated the Master to Starter relay bus bar, using copper strips. Drilled, on center, and shrink-wrapped the bar.
Four main wiring harnesses attach to the control unit. And each of the plugs has specific electrical assignments, wire gauges, and operations. There are several other connectors DB-9, etc., and a main power lug.
This system completely eliminates traditional circuit breakers, or fuses.
Some of the aircraft systems; 1) lighting (ext/int), 2) avionics, 3) comm, 4) flaps, electric, 5) A/P servos, and misc.
Control unit under ribs
VP-100 panel
VP-100 panel
Control unit & Panel
