Further adjustments and positioning of the various brackets and links that mount to bulkhead F-605. The links needed a 'twist' to align. The distances, angles, and fasteners were double checked.
Rough cut the holes for the canopy 'pins' to drop through for the latching mechansim to 'grab'. Will leave the final filing and adjustment for when the frame is mounted.
This is good enough to move on to the actual 'release' on the fuselage skin. Making sure that each task is secure enough to fit the next, but holding off on final 'tweaking' until the overall components are setup.
