RV-6A - GBC
RV-6A QB
Finishing Kit
5-5-2016
Cowl - Fiberglass (inlets) & oil access
Cleaned up the excess from the oil access door, and trimmed the fit on the cowl opening. Tested and adjusted push-button releases.
Trimmed and added more fiberglass aroun the 'other' inlet.
Other tasks; Torqued the close tolerance bolts on the wing spar. Added the straight fitting to the input of the Red Cube and connected hose.
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
