Worked on the secondary canopy latch (on roll bar) to loosen it up a little and design a notch to minimize the handle from turning on its own. Cut a notch in the top of the block for a rotating pin to slide as it turns, there will be a spring on the bottom to push the handle downward.
Traced and tested the battery and contactor circuits for the Master switch and starter. Double pole switch, to switch ON the battery contactor to supply electric power to the VP-X and therefore all devices through the ECB system.
