Lots of distractions from the airplane (life goes on) ... including EAA chapter mtg.
Got the bracket back from Gary Hertzler, for the AFP mixture cable. He milled a washer landing into a fillet that interfered with a fastener. Thanks Gary. Then cleaned-up a couple of burrs from lock-washers on the sump AFP server surface. Torqued a few bracket bolts, and cleaned off the bottom of the sump from a heater mount.
Sanded the mating surface of the empennage fairing and looked over fit again, and plans call-outs for the fasteners. Cut a template in butch-paper for the under HS fairing (to be made from .025 sheet alum).
Dropped off seat pan, and seat back at the upholstery shop.
