Received the L-Comm 90 degree DB25 (straight-thru) adapter to allow the SteinAir custom comm harness to clear the subpanel. This makes the entire comm harness (except power) to remain attached to the subpanel, and easily disconnect the panel mounted components to facilitate panel removal.
Also means that the right-angle adapter can remain connected to the SV-Intercom and the harness is disconnected from the adapter. Easier to reach when the canopy is raised.
Now the harnesses passing thru the subpanel are from the SV-EFIS, and they will be reached only from below the equipment compartment.
Worked on the mounting bracket for the engine control cables.
