As a result of securing the flap cross-over control tube, the operation of the incremental flap stops were not working accurately. Had to fire up the laptop and VPX Configurator app to re-calibrate the POS-12 stop points. Then reconfiguration of the SkyView EFIS sensor points to stops.
Then added the harnesses - bolted them in. Need to finish the tunnel cover, elevator control tube bolts, and manual aileron trim before closing up the seat pans.
