Brief Description: Various - elev, ailerons, trim tab
Added two additional layers to the elev trim tab horn, inserted clevis pin & cotter pin.
Added Tosten grip to the co-pilot control stick, drilled an exit hole in the aft side below grip to allow harness to be attached to exterior aft side of stick. The harness will be terminated on a D15 (M) connector. This stick will be removable for eliminating the dual control, or disconnecingd to limit manipulation of the control buttons.
