Added 2 #6 countersunk screws/nutplates to the sides of the cable mounting bracket. Finished filing and deburring the opening for the knobs to pass-thru for easy panel removal.
Adel clamps (from earlier panel) are not all aligned with the new lay-out and one needs to be moved.
Temporarily mounted the SkyView panel components and arranged harness wiring for adding retention clamps to the subpanel.
