RV-6A - GBC
Date: 8-16-2007
Number of Hours: 1.80
Brief Description: VS - HS - final drilled
Moved ahead quickly to recheck all VS & HS alignment components. Riveted the F-681 to the VS fwd spar, then clamped and drilled to the HS fwd spar. Finally, drilled the bottom HS spar holes.
It's SOLID ... amazing solid, and still needs a few bolts and some tightening. All I have to do is disassemble it all, debur, touch up primer, catalog the fasteners, vacuum up the chips (everywhere) and the re-assemble with the rudder in-place. Oh yeh, have to do the fiberglass tips, counter weights, and bolt it together tightly (to specs).
Then I'll probably have to disassemble it all again for something I forgot.
Riveted F-681 bracket
Drilled and bolted HS spar
Drilled aft HS spar bottom
