Reviewed the control stops and attach tasks for the HS/VS on the aft deck (F-614). Discovered that the QB kit again has something completed that will need to be modified. The fwd control stop for the elev should be under the aft deck but it currently has a simple spacer in there. I'll need to remove 5 rivets, and angle, and spacer.
Vans confirmed the need to replace the spacer with a custom crafted control spacer. Then there is another control stop on the aft side of the elevator horns.
