Brief Description: L Wing - aileron & flap (rigging)
With Dwg 21 taped to wing, went thru the call-outs for fasteners on the aileron and flap. Adjusted the spacers to match washer specs. Centered the pilot control stick (vertical) and adjusted aileron link tube to match wingtip. Then finished the flap linkage.
Flap had to be 'pinned' at the hinge before the aileron fasteners could be completed. This included safetieing the pin to the inboard aileron bracket. A single flap pin is inserted through the bracket.
Sure there will be some minor reviews of the rigging after completing the R Wing, too.
