Removed R flap to install sileron and added aileron per specs with fasteners as called out. (DWG 21)
Re-inserted pins (two) in the R flap and safetied the pins.
Forgot to torque the rear spar bolt and insert cotter key - re-do on Wed.
Adjusted the aileron control tube to center the control surfaces with pilot control stick and L aileron. Attached the flap link and torqued, Checked flap range of travel and then measured UP and DOWN range of travel for aileron.
