Brief Description: Forward canopy deck and associated parts
Big day today, I back drilled all the forward fuselage ribs and support brackets, then deburred, dimpled and etch primed parts, before riveting the assemblies together and installing them back into the fuselage.
The forward skin was then cleoced into place and all the underlying ribs back drilled / drilled to the correct size.
With this done the instrument panel attach brackets were back drilled and installed.
The next step is to install the vent brackets.
Forward fuselage skin back drilled and clecoed into place
Right instrument attach angles back drilled to panel
