Brief Description: Front cover, seat belts, seat and carpet
5 point harnesses are all installed on both sides.
The rear baggage area is done.
I need to make a couple of small cuts at the front of the carpet to allow it to slide forward about 1 inch, the restriction at the moment is the Radio antenna lead on the right side and the transponder antenna lead on the left, otherside the fit is perfect . I have not yet installed the inserts under the arm rests as forward seat covers still need to be screwed into place along with the fule line covers that sit against the front of the spar.
Tried out the right hand seat, wow really comfy.
Thankyou Classic Aero for a wonderfull product.
After Christmas its plug in the wings and drill the rear spar. Flush fuel lines and check fuel flow volume is sufficient. Do and Engine start :-) I have made a tentative booking for the spray painter for March...
Front access cover installed, and carpet in for a test fit
