Eddie's Zodiac XL Project
Date:  2-15-2009
Brief Description:  Drill holes in ribs for conduit and etch prime
This morning I marked and drilled a hole in all the rear wing ribs for the plastic wiring conduit to pass through, the holes where then edge finished and the ribs preped for etch primer. Its another high humidity day, so I'll leave the ribs for at least a day for starting the assemble of the right wing skeleton.
The right wing ribs in etch primer
Marked and drilled the hole for the conduit in all the ribs before applying etch primer
