Eddie's Zodiac XL Project
RV-7
Left flap
All the prep work is now done, so I can disassemble, deburr,dimple and etch prime before reviting the flap together.
Left control bracket back drilled into place and the leading edge bent the requried 6.3 degrees
Support bracket manufactured and back drilled to the spar
RV-7 Home
2573
Ailerons
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
219
Rear turtle deck
Roll Bar
Seats
Spinner
Vertical Stab
Wheels and brakes
554
Zodiac 601 XL Home
