Eddie's Zodiac XL Project
Date:  5-8-2008
Number of Hours:  0.50
Manual Reference:  HS-707
Brief Description:  Rivet left horizontal stab nose rib
The first job for this evening was to rivet the nose rib HS-707 into the top and bottom of HS-601PP, these where the first flush rivets that I am setting with the rivet gun and I was a little nervous, but it went very smoothly and I was pleased with the end result even though the primer takes a bit of battering, but that’s not a big deal, I aiming to actually have some primer between the dimple and the rivet itself and this has been achieved.
HS-707 Bottom nose rib riveted in place
HS-707 Top of node rib riveted
