DOUGs Web Site
Sling 2
Installed M4 rivnuts for inspection panels
I drilled out the 6 holes of each small inspection port and installed M4 rivnuts with the addition of Loctite 277 to prevent the possibility of nut spinning later in life.
drilled holes to accept M4 rivnut
applied loctite to rivnut OD.
installed rivnuts
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
